True HD/ Master Audio - can XBox One handle?
Discussion in 'TV & Multimedia via Xbox One' started by Per156GTA, Jul 3, 2015.
  1. Per156GTA
    Per156GTA
    Aug 18, 2007
    1,099
    87
    +254
    I received Maze Runner recently on Blu Ray and it didn't play on my Panasonic BD50 blu ray, but it played on the Xbox One. The thing is, playing by Xbox One, I don't get Master Audio. Does the Xbox One yet stream Master Audio, if so how do I get it to do so?
  2. cuke2u
    cuke2u
    Feb 7, 2007
    2,033
    63
    +241
  3. Per156GTA
    Per156GTA
    Aug 18, 2007
    1,099
    87
    +254
    Appreciated, thanks.
  4. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,403
    Bristol
    +10,110
    The XB1 can't bitstream lossless audio but it can convert it to PCM and output that which is every bit as good, just won't say DTS-HD or TrueHD on your amp.
  5. Per156GTA
    Per156GTA
    Aug 18, 2007
    1,099
    87
    +254
    Have set the xbox to bit stream lossless, but maybe a setting on my amp isn't right as I was getting dolby digital (basically same as I get on a HD transmission on a sky movie), which is not DTS HD or True HD. Guess I need to play around some more!!
  6. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,403
    Bristol
    +10,110
    As I said above there is no way to bitstream lossless, if you select bitstream it will just convert the audio to lossy Dolby or DTS depending on which you select.
  7. matosf
    matosf
    Jun 10, 2008
    68
    in your opinion is better PCM than Bitstream in XB1?
  8. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,403
    Bristol
    +10,110
    Well bitstream on the XB1 will limit you lossy formats, PCM is lossless so the superior option.
  9. matosf
    matosf
    Jun 10, 2008
    68
    Thanks .
  10. IrritatedBadger
    IrritatedBadger
    Oct 12, 2008
    5,840
    +2,056
    Uncompressed PCM is HD. It's sent this way so that party chat, game chat and other system sounds can be mixed together. You amp will probably just say PCM but that's the best option.
  11. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,403
    Bristol
    +10,110
    Oh I am fully aware of that and said as much to the OP it's just the bitstream setting on the XB1 is misleading because on the PS3/PS4 and all Blu-Ray players setting Bitstream will give you the untouched audio letting your amp do the decoding but on the XB1 it instead decodes the audio to either lossy DD or DTS.
    • Like Like x 1
    • Agree Agree x 1
    • List
  12. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,359
    2
    4
    137
    Garstang, Lancs
    +1,632
    Will it pass through Atmos?
