Troubleshooting a Denon DHT-500SD
Discussion in 'Home Cinema Buying & Building' started by Warhurst, May 2, 2005.
  1. Warhurst
    Warhurst
    Hello, this is the first time I have posted on here and I am looking for some advice please.
    We have had our DHT-500SD for a couple of months and not had any problems until this last week. The last couple of times we have tried to watch a DVD - the system has displayed "protect" and cut out altogether. It works fine again if you power off and just watch TV and only seems to be with the DVD. Has anyone else had this problem?
  2. PANASONIC MAN
    PANASONIC MAN
    it sounds like a processing error if its only on one source.
    the machine thinks its overheating.
    take it back to where you got it or give denon a call or e-mail. maybe they've heard of it before.
  3. Warhurst
    Warhurst
    Thats what we thought when it first happened, well the overheating bit anyway, so we took the STB off the top and all was well, until we tried to watch a dvd tonight !
    Cheers for the advice, we will get onto PRC tomorrow and send Denon a mail too.
    Ta :smashin:
  4. PANASONIC MAN
    PANASONIC MAN
    No worries pal. and good luck.
    and if you've only had it two months, you're entitled to a replacement, not a repair. (unless you got it off the net)
    Good Luck
  5. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    Can you explain this a bit fuller please.
    Adrenochrome.
  6. GizmoPower
    GizmoPower
    I've had my 500SD for a few days and its freezing after about 20 minutes of playing a dvd. It seems to be getting confused trying to auto-detect audio, and the disk clicks like mad, speeding up and slowing down, showing PLII on the display. Not good after a few days use :(
