Trouble with text on Sky
colin45
A friend is having trouble getting teletext when using satellite he gets text on BBC and ITV OK but if he tries text on a Sky program it starts to load and then the sign "loading" disappears any advice on how to clear this please
FRANTIC FRANC
Yes as ever try a force update first (search the threads for the procedure) if it doesn't solve the problem then suspect a faulty digibox.
Cheers, Franc
colin45
Cheers, Franc
Thanks Franc is the forced update the same for a plus box as it is for a HD box
