trouble with sonicstage
Discussion in 'Headphones, Earphones & Portable Music' started by 2pac-is-alive, Aug 5, 2005.
  1. 2pac-is-alive
    2pac-is-alive
    just copied an album to sonic software and because there was more than 1 artist two of the songs were listed seperatly how do i make it all come under the 1 album
    Thanks for any help :lease:
  2. shadowritten
    shadowritten
    Sonicstage lists all albums and tracks by artist. This is annoying, but unavoidable.
    In My Library, select 'view all tracks'. Find the first track of the album concerned, click once on it to highlight it, then hold down the shift key and click on the last track of the album once. All the tracks in that album should now be highlighted. Right-click anywhere within the highlighted tracks and select properties. You'll see a small tickbox, saying something along the lines of 'tracks in compiliation'. Tick this box. This should now mean that in Sonicstage the album will always show correctly. It won't be a problem when you transfer to your player as it will just show as an album.
    If, for any reason, you delete the tracks from your library only, then re-import them, you'll have to follow the above process again as Sonicstage will forget what you've told it to do.
  3. 2pac-is-alive
    2pac-is-alive
    tanks alot for the help
