Trouble with lead from Sky box to ProV
Discussion in 'Projectors, Screens & Video Processors' started by obiwan, Dec 28, 2002.
  1. obiwan
    obiwan
    Nov 22, 2002
    319
    Devon
    +5
    What was I thinking.
    I bought a Scart to SVideo from Keene.
    I figured this would take signal from Sky box to ProV, I do not have SVideo on Sky box.
    But I also cannot output svideo signal from Sky box either.
    I think I just wasted money on this cable.
    How do I connect Sky box to ProV for best PQ.
    thx
  2. JonMace
    JonMace
    Nov 20, 2002
    2,536
    83
    Kent
    +207
    Is it a cable or a convertor box? Straight foreward scart->svideo cables are always problems (never really got one to work). But if you have the keane RGB to SVideo convertor box (£70 Maplins) there should not be a problem, so maybe the convertor is faulty?
  3. Kramer
    Kramer
    Sky digiboxes do not output S-video via scart. Just composite & RGB.
    You'll need either an S-video equiped digibox (Grundig GDS310/2 or Sky+ box), or, as mentioned above, an RGB/S-video converter.
