Question Trouble printing with a cCanon600R
Discussion in 'Computer Peripherals & Consumables' started by chaz, Jun 7, 2015.
  1. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    I hope someone can help here please I own A Canon MP600R a day ago i had to replace one of the cartages I placed in the Printer And got this message UO52 "This type of print head is incorrect.Install the correct print head". The print cartages are not the official one but ones i have brought from www.cartagesdiscount.co.uk do you think they have sent me the wrong cartages or is there something wrong with the printer. I know if I switch the printer off & then on again The printer will print but after it has done the print it goes back to that message again
  2. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    Anybody Please?
  3. JayCee
    JayCee
    Jan 20, 2004
    23,996
    Lanarkshire
    +2,616
    Most printers will throw up an error message if you install a non-original cartridge.
  4. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    I have not had this happened before when I have used non cannon cartages is there a way around this ?
  5. JayCee
    JayCee
    Jan 20, 2004
    23,996
    Lanarkshire
    +2,616
    Sometimes there's a code "hack" you can enter to get around it...Google it or contact your cartridge supplier and ask them.
  6. chaz
    chaz
    Apr 7, 2003
    4,060
    107
    sussex
    +264
    I think I have managed to solve the problem. Found this
    MAJ 14/10/14
    Error U052 appears on these Canon printers: MX850, MP540, MP530, MP600, MP610, MP970 and others...
    Message error: The type of print head is incorrect install the correct print head U052
    Solution 1:
    • Remove and replace the cartridges.
    Solution 2:
    • Insert new cartridges
    Solution 3:
    • Reseat the print head to correct print issues or clear error.
    Solution 3a (thanks to Tony LeBaigue):
    • Remove the ink cartridges.
    • Remove the printhead: cleaned the rear contacts with a cotton bud and surgical spirit.
    • Left the part 5 minutes to dry.
    • Install the printhead and the cartridges.
    • The printer wil be into printhead clean mode and will return to normal mode.
    Solution 3b (thanks to Arjen - Canon MP610):
    • Power off the printer.
    • Press and hold both selection buttons underneath the screen, and switch on the printer.
    • After a long start up the 'copy' screen appeared, and it printed a copy of a sheet.
    Solution 4:
