Tripped it out?
Discussion in 'Subwoofers' started by Jstn, Aug 29, 2004.
  1. Jstn
    Jstn
    Hi, I'm new to my nice MS309 and I was watching the intro scene to Attack of the Clones; the bit at the very beginning where the silver ships comes flying in overhead. My amp was at about -30db! and my sub just a smidge under half volume. Anyway instead of playing it properly is just sort of made one big BOOM sound then stopped responding. I had to switch it on and off to get it going again.
    Did I just trip it out by trying to play it too loud?
    Thanks,
  2. Stellavision
    Stellavision
    Apr 7, 2003
    2,410
    Southsea, UK
    +105
    That scene can be a sub killer, but usually only at near reference levels.
    Have you calibrated all your speakers? If you were only listening at -30db on a correctly calibrated system you should'nt be worrying about tripping the protection circuit or worse blowing the driver!
    If you have'nt already calibrated to -75db I would highly reccommend you do.
    Hopefully you just tripped the protection circuit and have done no lasting damage.
