Tripod selection Criteria for Camcorder use
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Topefisher, Jan 21, 2008.
  1. Topefisher
    Topefisher
    Dec 5, 2006
    164
    Hyde, Cheshire
    +13
    What are the main considerations when selecting a tripod specific to camcorder use.
    There appears to be 2 x main common price bracket ranges i.e. those around the £30-£40 mark and those at the £75-£100 mark.
    At the moment I am looking at the lighter models of around the 1.3kg mark where I know that I will have to loose some stability for the lightness.
    What should I be looking for up at the business end?
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    There is a huge range of prices of tripods... you can get ones for several hundreds of pounds (or even thousands...)
    You want a smooth, fluid head. Better tripods will have a fluid head, where the tension is caused by fluid (oil). Cheaper ones have plates and use friction.
    You want to be able to pan smoothly.
    For budget tripods I like Velbon, DV7000 is heavy but good. There are cheaper lighter models which are also decent.
    Manfrotto makes good heads, but you are talking £200 including a decent set of legs.
