CooperUK
Having pondered the idea of a proper screen for a while, although on a limited budget, and with the WF being a consideration, I have come up with the idea that a tripod screen might do the job.
Has/Does anyone used/use a tripod screen?
Does the tensioning bar reduce/eliminate screen curl?
Do you find it easy to set the screen to the various widescreen ratios?
Any feedback would be greatly appreciated.
