Tripod recommendations.
Discussion in 'Photography Forums' started by RimBlock, Aug 22, 2005.
  1. RimBlock
    RimBlock
    Nov 5, 2002
    530
    Singapore
    +15
    I have a mini tripod for my Cannon 350D which was purchased from Jessops for £17. Although it is fine for the cost, the tripod head is fairly cheap and nasty (as you may expect).
    Can anyone recommend a full sized tripod that is only going to be used for a studio and pref has spirit levels. Weight is not much of an issue as it will not be move around that much.
    RB
  2. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    Budget?
  3. RimBlock
    RimBlock
    Nov 5, 2002
    530
    Singapore
    +15
    Budget......
    Open to suggestions but around the £100 mark would be ok. More if warranted although an idea of what I am going to get for the extra would make it a lot easier for me to weigh up if the extra expense is worth it to me.
    Many thanks
    RB
  4. ASH1
    ASH1
    Mar 1, 2003
    1,208
    +61
    Hi, I have a Benbo trekker MK2 for my 350D, does everything I need.
  5. tomson
    tomson
    Jul 19, 2000
    1,918
    Berk'amsted
    +187
    I have a Manfrotto 055 - can be had for around £105 for just the legs.
  6. RobertP
    RobertP
    Nov 21, 2002
    522
    19
    Woodford Essex
    This is the thread where I asked the same question
    The Feisol tripod + Manfrotto head that I ended up with is over your budget. The tripod is light but solid and the head is heavy and solid :)
    Having gone from a tripod with 'flip locks' for the leg sections I do find the twist locks slower to use, plus you have to remember to tighten them in sequence or the sections just spin. No doubt I'll get used to it. It is certainly a big difference in accuracy - the camera now points at what I want first time without any nudging + swearing.
  7. Radiohead
    Radiohead
    Dec 24, 2001
    4,295
    Amazingstoke
    +433
    The Velbon Sherpa 750n comes in at around £80 inc a decent head. Recommended for under £100.
  8. RimBlock
    RimBlock
    Nov 5, 2002
    530
    Singapore
    +15
    Thanks,
    That gives me a fair amount to go searching around on now.
    RB
