Trimming a big vid file ... action cam
imageracer
Hi All
New here and have a minor problem ---- I use an action cam on my racecar and in the heat of the moment often forget to switch it off ----- I use an android phone and chromebook ..... there are some good web based editing apps out there but most have a quite small file size limit for uploads and reject the Gb size files I'm stuck with---- does anyone have a suggestion as to how to trim off the 15 minutes of dross at the end so that I can work on the bit I want to keep?
Regards
chrishull3
Hi All
Regards
Editing software like power director will render your clips to what size you require.
