Trilogy 2 RGB Switch Box
Discussion in 'TVs' started by deye, May 7, 2003.
  1. deye
    deye
    Anyone bought this switch box which also acts as extending the no. of RGB scart sockets ?
    Any opinions will be much appreciated.
    deye
  2. SOUNDSTYLE
    SOUNDSTYLE
    Oct 4, 2002
    1,228
    +46
    I don't know anything about the Trilogy, but I've heard about people being quite happy with one which is sold in Argos for £9.75 (if I remember correctly), and there's also a good one sold in Dixons for £19.99.
    Hope that helps.
  3. NeoBlade
    NeoBlade
    Yep ^_^ I'm very happy with the Argos one considering its pricepoint and image quality produced. Of course you can go all out and buy the Quattro+ for a mere £70 but its your call to decide how much quality you can notice between the two, if at all.
    I've recommended the same scart box/splitter to my gaming and TV colleagues and I haven't heard a bad word from it.
    For a tenner you can't go far wrong and if you don't like it, give it back ^_^
  4. staxdoobie
    staxdoobie
    May 7, 2003
    325
    +35
    But am I right in thinking that the Argos switch doesn't feature auto widescreen switching?
  5. deye
    deye
    Hi guys
    Thanks for the responses.
    I am looking for a switch box to connect dig box and dvd RGB outputs to the only one RGB input on the telly.
    I don't know if the ones sold by Argos or Dixons are okay for RGB connections. They manual ones too, I suppose.
    The Trilogy 2 costs £60 but it has many features :
    Automatically detects which of the three inputs devices has last been switched from standby mode to ON.
    A push-button selector switch on the front panel will override this function.
    Individual LED inidicators show which input is selected.
    Automatic scart switching of the TV RGB mode.
    Automatic wide-screen switching (Pin 8 output from all Digital Satellite/Cable boxes allows automatic 16:9 - 4:3 picture).
    Unless someone know of any switch boxes for a cheaper price having these features ???
    deye
  6. SOUNDSTYLE
    SOUNDSTYLE
    Oct 4, 2002
    1,228
    +46
    There's a thread on 'Plasma and LCD displays' which I think might be the scart box you're talking about.
    Look for 'Keene scart commander - superb'
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Well the £15 JVC one i bought from Dixons works perfectly totally passive so only one device on at a time but 4 RGB inputs one gold plated output!!!!!
    Great for GC,DVD,STB
  8. Sessen Ryu
    Sessen Ryu
    May 15, 2002
    992
    Surrey
    +81
    I brought a RGB scart splitter from maplin electronics, sure, it worked, but the picture was noticalby degraded.
    It's a joke that most tv's only come with one, or two at the most RGB sockets.
    I need three inputs and am always having to swap scarts around. pain in the arse.
  9. Ian Maurice
    Ian Maurice
    A splitter is quite different to a switch. The switch can be essentially passive where as a splitter can't.
  10. NeoBlade
    NeoBlade
    The Argos one supports RGB so it also has auto widescreen switching ^_^ Picture quality hasn't dropped as well and for £9.95 you can't argue. If you don't believe me just pick one up and test it.. If you don't like it then by all means return it. It has a seperate RGB button. A-B, A-C link buttons (I never use these), and inputs A, B and C to select from.
    The only thing missing from this are the flashy LEDs but if you seriously want that featue just add it yourself for pennies ^_^
    Sure there are more expensive ones about but if I were to spend the cash then the Quattro+ would be the only option for me. The Argos scart splitter has done a superb job for me when I didn't have my component cables, but its still in use now for my Sky and other consoles.
  11. Kevo
    Kevo
    Aug 23, 2001
    5,364
    Manchester
    +146
    I use to have the Argos SWITCH box (B-Tech BT21) and highly recommend it.
    It's important to realise that switch boxes and splitters are NOT the same.
    I recently upgraded to the QUINTRO+ (NOTEthe QUATTRO is the older version and does not support WS switching) for two reasons.
    1. I got fed up of having to get out of my chair to switch sources (call me lazy!)
    2. There's a chance that I might get a fourth RGB device (Freeview box).
    I recommend the Quintro as long as you don't use the hi-fi audio ootputs to an amp as they distort the sound.
  12. NeoBlade
    NeoBlade
    Yeah the Quintro+ is rather sweet. I only have 2 RGB sources now as almost everything visually uses component leads for progressive scan but if you want to spend the cash I can't argue with the Quintro+.
  13. deye
    deye
    thanks for the info, guys
    How much is the QUINTRO + please ?
