trilogy 2 problem
Discussion in 'Satellite TV, Sky TV & FreeSat' started by natty, Nov 23, 2003.
  1. natty
    natty
    Nov 23, 2003
    413
    28
    Nottingham
    +41
    I have just purchased a trilogy 2 scart connecter, to which i have a dvd, freeview box, and playstation 2 conected. they are all configured to output rgb. the problem is whenever there is predominately white screen,whichever source is selected,the picture starts rolling. could anyone explain why this should be. I think there must be a fault with the connector.
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    What are they connected to? I suspect the trilogy, I've had trouble with them in the past, picture dropouts withRGB converters. You should have a 9v power supply there days, they upped the voltage to try and get it to work. If yours is 6v there's your problem. If it's 9v, then just maybe the fix isn't as good as it should be.
