Sparky4066
I really hope someone can help - I've upgraded my TV to the Samsung Q90T and plan to get the XBox Series X to replace my Xbox One X.
Current setup is XBox One X >> Hue Sync >> XXXXXX >> Q90T
Where XXXX = I've tried soundbars:
Samsung Q950T - great with eARC but crap for sound in room with 20' ceilings - while Atmos filled the room, was way to tinny and not enough sub
Nakamichi Ultra 9.2 - great sound but no eARC. ARC requires XBox go to Soundbar to avoid lipsync issues which loses VRR/HDMI 2.1 abilities
I'm looking at returning the Samsung Q950T as the Nakamichi is just better sound.
I'm hoping the Klipsch Cinema 1200 will come and be best of both sides and still provide the sound fill in the room.
But I have one more issue - audio drops with Atmos enabled. This will likely happen with the Klipsch as well due to the Atmos MAT buffer issue.
That said - is there a "next gen" AVR like the ones from Yamaha or Denon that support the XSX features with the ability to add wireless surround and subwoofer that would allow me to get best from all worlds?
I obviously have approx $1500 to work with if I return the sound bars. My old receiver is gone, but my old speakers are decent Athena bookshelf about ten years old.
I'd love to get a solution of receiver but also have wireless surrounds that are Atmos capable (upfire is fine, but SRS-like tech like Nakamichi offers works too)
OR - should I stick with the Nakamichi (or Klipsch) and get the HDFury Arcadia to split off the audio, allowing the HDMI 2.1 to go to the TV and have the TV's audio think it's plugged into an eARC device going to the soundbar?
Hell, will the Arcadia do what I'm expecting (it's slotted to go to non-eARC TV, where my issue is that I have an eARC TV, but my audio is ARC)
Thank you!
Thank you!
