Tried Changing Resolution Now Black Screen
Discussion in 'Apple Forum' started by sammy4499771, Sep 14, 2007.
  1. sammy4499771
    sammy4499771
    Mar 12, 2006
    589
    +93
    Hi All
    Just got a mac mini and connected to my sony lcd via dvi to hdmi. I used SwitchResX to change the resolution to 1366x768 but now when I boot up the screen is there for the booting process but as soon as the desktop comes up I get a black screen and now have no way of changing the resolution to something viewable. Can some one help me out with this? Is there a way of booting up in a standard resolution e.g. 1024x768?
    I've only had the computer for an hour.
    Thanks in advance.
  2. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    Q: I've defined a new resolution and rebooted, now my screen is black. Is my monitor destroyed ? How can I go back to the light ?
    A: First, try to reboot in safe mode. The file named "com.apple.windowserver.plist" in the Preferences folder contains the resolution that the System tries to use at startup. Deleting this file helps generally.
    If this solves the problem during thre reboot, but not in your user account, a similar file named "com.apple.windowserver.XXXXX.plist" exisit in your own /Users/yourname/Library/Preferences/ByHost folder. You can remove this file to get back the standard resolution in your user account.
    If finally, nothing above works, try to press the "reset" or "factory defaults" button in SwitchResX Control for your monitor. This will delete all changes that you have made for this monitor. At last resort, send me an email and I'll work with you to correct this issue.
    http://www.switchres.info/html/SRX/FAQ.html
  3. rorton
    rorton
    Dec 26, 2004
    361
    28
    +36
    do you have access to a VGA cable (PC monitor type cable) and does your LCD have a VGA input?
    If so, id stop using the DVI/HDMI lead and use the VGA instead.
    I had no end of trouble using DVI/HDMI with my samsung TV. Something to do with the odd resolutions these LCDs use (not 1280 x 800 for example)
    I bought a VGA lead, plugged this is, and it all worked perfectly ever since.
  4. sammy4499771
    sammy4499771
    Mar 12, 2006
    589
    +93
    Thanks alot Sam for the information, will give it a go. Have you had much luck with using switchres x? I want to get the setting right for my sony kdl26s2030u, it has a 1366x768 resolution. Have you got any tips for me?
  5. sammy4499771
    sammy4499771
    Mar 12, 2006
    589
    +93
    Rorton I need to use the digital connection as i only have the hdmi cable channel in the wall. I know its going to be hard but I really want to make it work.
  6. raigraphixs
    raigraphixs
    Jul 11, 2001
    65,411
    +25,723
    Tried zap the PRAM?, to see if the res default back. Holding CMD + OPT + P + R on startup.
    I had this happpen on older macs a few times, alway eventually got back working., scary though :D.
  7. Greybeard
    Greybeard
    Jan 23, 2007
    352
    28
    Leicestershire
    +30
    Have you tried booting from your system disk?
  8. jont
    jont
    Apr 8, 2002
    4,335
    near Aylesbury
    +577
    Sammy - you shouldn't need to use switchres ...
    Restart and hold down the shift key to do a safe boot ... go to display and click the check display button - the mac should interrogate the screen and return a new set of suitable resolutions - 1366 x 768 should be one of them ...
    Jon
  9. sammy4499771
    sammy4499771
    Mar 12, 2006
    589
    +93
    Thanks John but I can't see check display button. i current have the mini running at 1280 by 720 but its surrounded with a black border to fill in the missing pixels. It doesn't give me the option for 1366x768.
  10. jont
    jont
    Apr 8, 2002
    4,335
    near Aylesbury
    +577
    Sorry - that should have been 'Detect Displays' ...
    My mini reported that res back when hooked it up to my HD plasma
    Jon
