Tried a new card and lost my display-Help Please
Discussion in 'Desktop & Laptop Computers Forum' started by Ged, Oct 30, 2005.
  1. Ged
    Ged
    Apr 29, 2002
    962
    +25
    I have tried to fit a new graphics card for the DVI feature, loosely following the instructions which were a little vague and I have managed to loose the display after the initial black and white screen and Windows XP black and colour screen.
    The last thing I remember doing was disablingor removing something in the
    control panel/settings/advanced section.
    Ended up with the new card makes the m/board beep only, an old drive works, and the current drive is the inital problem.
    Does any one know how to get the display back?
    I tried putting the XP disc back in but after file transfers etc the reboot ended with the black screen, now it won't load the XP disc :oops:
    Looks like a trip to the shop, but any help appreciated, thanks.
  2. The Dude
    The Dude
    May 21, 2004
    6,772
    Beverley, East Yorkshire
    +3,242
    see if XP will boot into safe mode first..
    hold down F8 at the initial BIOS screen, until you get a list of choices displayed, 'safe mode' should be the top one..
    If XP boots, then the card is OK, it's just a driver problem.
    Uninstall the card driver software whilst in safe mode, then reboot XP normally and have another go at the driver installation. :)
  3. Ged
    Ged
    Apr 29, 2002
    962
    +25
    Hi Dude, as usual, I have wandered far from the safe path! The current situation is the card is out of the PC, when it boots up I get the initial black and white screen then the black XP then nothing, I can get the BIOS to come on.
    I don't remeber all of last nights events but it did at one point start with putting the XP disc in (the blue set up screen only), now I get nothing past the first two screens, it still has the HD light and an older HD will work.
    I am sure I switched off something in the advanced settings of the display, thats when I retried the card and never got it back on.
    I hoped sticking the XP disc would sort it out, it went through the motions a few times and I am sure it still is doing something as it whirs away but I cannot see it.
    I will retry F8 and hold it down longer.
  4. Ged
    Ged
    Apr 29, 2002
    962
    +25
    Managed to use F8 to get to the set up, safe mode just sat there with a full screen of text and no action, last good config and others left it hanging with a blue windows set up starting screen. Any more ideas? I will probably take it to a shop this week
    Thanks,
    Ged.
  5. The Dude
    The Dude
    May 21, 2004
    6,772
    +3,242
    safe mode does take a very long time to boot up, all you get is the text screen for a good few mins sometimes.. how long did you give it?
    Def. leave it a good five mins when booting into safe mode...
    If that doesn't work, looks like it's time to reinstall Windows, as I think you may have trashed the Windows install by partially running Windows setup from the CD, if I've read your first post right? :(
  6. Ged
    Ged
    Apr 29, 2002
    962
    +25
    I am sure I left it for a good five or so, just a load of dos like text and no activity, i will retry. Re the setup, yes, I have tried a lot, inserted the XP disc which sort of went through some set up but didn't fix it. Looks like a call out to try and save my photo etc.
  7. mjn
    mjn
    May 24, 2001
    24,807
    Herts, England
    +13,774
    Nothing like knowing what you're doing....
  8. Rambles
    Rambles
    Jul 14, 2004
    10,541
    167
    UK
    +2,216
    Can you take the hard drive out, access it from another pc, save / back up your data - then do a clean install of xp - or ask someone to do it for you...
  9. Ged
    Ged
    Apr 29, 2002
    962
    +25
    ....and I never fail to forget that advice, even after the many disasters!
    Lisa, yes, I will do that (not personally), I am going to drop it off at a shop in the near future. Lesson learned me thinks :lesson:
