Tricky?
Discussion in 'Cables & Switches' started by mevetts, Dec 15, 2003.
  1. mevetts
    mevetts
    Oct 31, 2003
    439
    I have just purchased my first DVD player a Panasonic S75. however, i have a pair of old Wharfedale speakers that i thought I may use temporarily to bolster my fairly ok sounding tv speakers.
    :lesson:
    However, I am not sure how to connect the DVD to the speakers. the speakers have the old styly hi-fi connections where the wire spilts in into 2 and you pull back th clip and stuff the wire in and it springs closed. Red to red and black to black.
    Can I connect these type of speakers to my DVD player? :(
    Thanks,
    Mark.
  2. CARLOS
    CARLOS
    Feb 11, 2001
    5,952
    WEST MIDLANDS
    +1,212
    No !!
    Don`t even try as it may overload the output from the player.
    The output from the DVD player isn`t designed to drive speakers, You need an Hifi or Av amp to drive the speakers then the DVD player connects into this.
  3. mevetts
    mevetts
    Oct 31, 2003
    439
    Thanks for the advice Carlos, guess I will try the approach you suggest and start saving for my Cantons!
