Tri-Wiring Speakers
Discussion in 'Home Cinema Speakers' started by Hawklord, May 13, 2003.
  1. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +295
    I currently use Van Den Hul Teatrack bi-wire to connect my amp to the speakers.
    I'm going to be probably buying Linn Ninka floorstanding speakers and was wondering how to go about tri-wiring these speakers.
    I have not been able to even find a source of tri wire apart from Linns own k600 speaker cable. Would this be suitable? Or would you advise another manufacturer.
    Could I use my teatrack and by a single length of similar cable for the third driver?
    Is it realy necessary to tri-wire these speaker to get the best out of them.
    Any thoughts would be appreciated.:)
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    +295
  3. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    +295
    Thanx for that- you've saved me some £'s. Until I decide to go the active route that is.
  5. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    No probs Hawklord...been there and back with a triamped active Linn Keltik/Krell stereo system,prior to going down the AV path..if you do go active later and need any help,let me know.
