tri pole rear speakers
Discussion in 'Home Cinema Speakers' started by karkus30, Jul 14, 2004.
  1. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    I need some rear speakers to complete my set up. Been looking at Energy crs tri poles at 299.95 each. That puts them into a competitive price range, so, anyone suggest any alternatives ? S/H is fine. The deciding factor apart from performance is the ability to blend with the surroundings. The Enery speakers have a curved front and are available in all white.
  2. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    You could look at the Mordaunt Short THX certified MS504 Dipoles. I am thinking of a pair of these as well later in the year, and they should add weight and authority to most systems.
    I think they are currently available in Black and Maple.
  3. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Im really wanting tri poles due to my seating position being right up against the wall so dispersion isnt great.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,906
    Seeing as you have gone down the SVS / AVC10SE route why not consider the M&K K4 tripole rears which pack quite a punch for their dimunitive size and are available in white.
  5. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,092
    notts.
    +64
    I use k-4s on the back wall about 7' up its the only place i can put them my sofa is against the back wall also.Performance wise they are excellent and blend in very well with my m&k 850s and svs subwoofer.I used to have mission m7ds and the little k-4s easily outclassed them.
    Cheers Gonzo.
  6. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Thanks chaps, best place to buy? :rolleyes: have to change my name to Karkus J
    soon :D
  7. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    am also using k4s very happy with them, dont know of anywhere that sells mk speakers at discounted prices let me know if you find someone that does
  8. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    Gecko are the Uk distributer for M&K. You can mail tham at [email protected]
    I spoke to them a few months ago and they were very helpful.
  9. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    i also found them very helpfull when i wanted some platinum coloured grills for the k4s bought them direct from them
  10. bass007
    bass007
    Apr 8, 2004
    1,514
    london
    +36
    I also use the K4's they are extremly compact, and the sound dispersion is amazing for the price., also thinking of getting another pair
  11. karkus30
    karkus30
    Jul 29, 2002
    13,997
    +1,236
    Still £500 a pair for rear speakers, not exactly cheap.
  12. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    Agreed. They cost over 3X more than my Mission M7D's, however they are significantly cheaper than the £900 B&W DS7's.
    My surround speakers are probably my systems weakest link at the moment but they will have to make do for a while.
  13. Kazman
    Kazman
    Jan 14, 2004
    5,351
    Luton, Bedfordshire
    +142
    I'm thinking of the MS504 Dipoles, how would the M&K's compare?
  14. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,200
    2
    +3,674
    FYI its 506 :lesson: ;) (and my new ones arrived today :smashin: ).
    The M&K unit is smaller and lighter than ours and is easier to hide. The 506 is a big sod and weighs about 6kg each. In film terms there isn't much in it, all I will say is that the 5.25 in CPC driver in a 506 is going to match better with the 5.25in and 6.5in drivers you have already. However, you could use the smaller size of the M&K to persuade Mrs Kaz to speak to you again after you buy an SVS.
  15. neildhunter
    neildhunter
    The manual for my Denon 3802 recommends 6-16ohms for speakers - would there be any real problems with a pair of M&K K4's being 4ohms and coupled with 5 B&W VM1s to complete a 7.1 setup?
  16. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    I was in a similar dilema wanting the K4's but my Pioneer also recommends 6-8 ohm loads. The 4 ohm load on your amp could potentially cause a overheating problem, although I know others have driven 4 ohm speakers under similar cercumstanses with no reported incident. I decided the risk to my £900 amp/receiver wasn't worth the risk.
  17. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,200
    2
    +3,674
    I run a stiff 4ohm load across the back of my Pioneer AX3 (and a buddy runs a full 7.1 THX pack with 4x4ohm rears on a VSXD2011) without a squeak. Most rears seem quite sensitve even at 4ohms so it rarely seems to be a problem. It is when you have a 7 channel Dynaudio system that things get fun.
