Trettioen Lights (plasma Bling)
Discussion in 'Plasma TVs Forum' started by willsmeister, Oct 24, 2005.
  1. willsmeister
    willsmeister
    Just a little info - according to Ikea in Bristol they have discontinued this line so if you want some get them quick while they are in stock
  2. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Yeah get some, at first i did'nt think it enhanced viewing. Then i was playing xbox with some friends and did'nt realise they where on and switched them off, everyone wondered what had happened.
    Good stuff these lights :thumbsup:
  3. acrmorris
    acrmorris
    Jul 5, 2005
    326
    16
    East Grinstead
    Blimey, it says "new" on the website! Just proves things are obsolete these days before they hit the shelves :rotfl:
    I agree RHCP, a big improvement and significant 'cool' factor for very little outlay. Snap them up while they're still available!
  4. DFL
    DFL
    Apr 27, 2005
    169
    +5
    is it like having your own ambilight? for £21??
  5. acrmorris
    acrmorris
    Jul 5, 2005
    326
    16
    East Grinstead
    Depending on what colour you go for. I went with the white, which is very white compared to anything the ambilight produces, but it's not too bright so I think it enhances viewing. Also, completely silent whereas ambilight is quite noisy depending on which colour it's producing. Obviously, ambilight is dynamic as well.
  6. wonderloaf
    wonderloaf
    Jul 5, 2005
    264
    Hampshire
    +6
    Any chance of some pictures?
  7. willsmeister
    willsmeister
    Photo as requested. And yes it is a PS42S5HX...as i have said before - don't believe the hype!! :nono:
      Size:
      73.4 KB
      4,727
  8. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    How do you power it? Does it connect to the mains or to your light switch somehow?
  9. willsmeister
    willsmeister
    In the box you get 4 led strips along with 4 wires (one for each strip) which plug into a small connection box which in turn is on a bog standard mains wire with an inline switch along with a normal plug. Nothing to do but put them together..
  10. wonderloaf
    wonderloaf
    Jul 5, 2005
    264
    Hampshire
    +6
    Cheers willmeister.....although they look great, don't know if I could get along with them.
  11. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    what do you mean by dont believe the hype? Are you referring to the screen?
  12. willsmeister
    willsmeister
  13. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    whats good/bad about it? and Piers and gordon will have a field day when they see this thread...........
  14. Lionheart
    Lionheart
    Who cares what anyone thinks...if it looks good and you like it what the hell
  15. stevedster
    stevedster
    Jan 13, 2005
    1,132
    48
    Birkenhead
    +41
    hmmm, interested in these, tell me, did you stick them to the wall or to the back of your panel?
  16. speedfreak75
    speedfreak75
    Hi I looked on the Ikea web sight but not locate these lights any chance in pointing me in the right direction
  17. acrmorris
    acrmorris
    Jul 5, 2005
    326
    16
    East Grinstead
    Try this link
    http://www.ikea.com/webapp/wcs/stor...Id=10101&storeId=7&langId=-20&productId=11158
    They are around a foot in length, 1/2 inch wide and probably less than 1/4 inch thick. Comes with double sided tape and I've just stuck 2 strips either side of the wall bracket. They don't produce any heat though, so they would go on the back of the panel or the wall no prob. Cables plenty long enough for a decent run as well.
  18. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    Any more pictures? Does anyone have the white version?
  19. acrmorris
    acrmorris
    Jul 5, 2005
    326
    16
    East Grinstead
    I have the white version. Will take some pics tonight with them on ond off for comparison.
  20. Dozer
    Dozer
  21. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +483
    well done Dozer, was just about to ask for an alternative source!
  22. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    acrmorris - any chance of those pics?
  23. leedebs
    leedebs
    Nov 29, 2002
    1,896
    63
    +111
    If anyone is interested although I haven't got the Ikea lights mentioned in this thread I do have the ones that w3dal mentioned on the get your plasma out for the lads thread.
    They come from Habitat in 3 colours (blue/red/white) for £20, I chose the white.....see attached photos, sorry about the quality.....they do not do the lights or the screen image for that matter any justice.
    Really do improve the perception of contrast IMO they work really well & do not get hot even after being on all evening.
  24. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    leedebs any chance you could point us to what they are called on the habitat website? Also any chance of some pics of the lights close up/ at the back of the screen?
  25. kamaran
    kamaran
    Jul 20, 2002
    688
    +24
    Also Dozer, which ones are the same as the ikea ones in the website you posted? I am thinking about going for the white ones - should I be considering the:
    SD Super-thin LED Ribbon Strip - White
    It says the dont go over 50 degrees Celsius - surely thats far too hot?!
    What about these?
    http://www.ultraleds.co.uk/product_...d=798&osCsid=64f9fbb5668f21df8779b262bba6193c
    Or should I just try to source the Ikea ones?
  26. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +483
    I think the 24v ones look the job, don't forget the transformer too
  27. MacReady
    MacReady
    Jun 25, 2003
    2,589
    3
    Dewsbury, West Yorkshire
    +242
    They can be used for other things as well as Plasmas ;)
  28. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +483
    looks good MacReady!
  29. MacReady
    MacReady
    Jun 25, 2003
    2,589
    3
    +242
    I am actually not that keen on the green ones and tend to just have the blue ones behind the speakers on all the time.
    They look really good with the projector screen down :smashin:
  30. leedebs
    leedebs
    Nov 29, 2002
    1,896
    63
    +111
    Must admit the blue ones look really cool.............might have to invest in those as well :(
    Not sure how good they will look in my room though, as the room is fairly neutral. Thats why the missus prefered the white ones I recall.
