Travelling abroad with an IXUS II??
Discussion in 'Photography Forums' started by astonbilla, Jun 18, 2004.
  1. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Guys i hope you can help
    I got the wife an isux II for Christmas, which i have to say she loved.
    We are off to the states in August and she wants to bring the camera. I have no idea if we can or not.
    How do we get the memory cards over? will they get damaged by scanners etc? can you buy an adaptor to charge the camera overseas?
    any help would be great guys - sorry for the stupid questions
  2. Brian110507
    Brian110507
    Just put the memory cards in your camera bag and send them through with the rest of your belongings you will have absolutely no problems at all putting them through airport scanners. We have travelled the world with digital camera, memory cards, digital camcorder, tapes, batteries etc. and never had a problem
    The voltage in America is different and is usually 110 Volts, most chargers sold in England are suitable for use between 110 and 240 volts just check the name plate on your charger.
    They do use different plugs though so you do need a mechanical adapter to make the plugs on your charger fit their mains sockets, I would recommend you take at least one of each of the following. :-
    http://www.keene.co.uk/cgi-bin/codesearch.pl?KAM2
    http://www.keene.co.uk/cgi-bin/codesearch.pl?KAM1
    You may need more than one if your wife like mine has to take her own travelling iron and hairdryer. (make sure they also work on 110 volts)
  3. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Thanks for the reply
    So let me get this right, if i take my british battery and charger and attach a us plug adaptor, i can plug it in over there and charge it without it getting destroyed?
    If so this is great news, i thought i would have to get a different charger etc
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,378
    Somewhere in South Yorkshire
    +5,764
    It won't get destroyed - the US voltage is LOWER than ours, so unlikely to cause damage.
    Depending on your charger, it may charge slowly or not at all. Take a close look at the small print on the charger itself - it will almost certainly give you its acceptable voltage range, which will probably be 100-240 - but check it for yourself.
    If it is only (say) 200-240 then it may not work.
    If you have a dual-voltage shaver outlet in your bathroom, you can try it on 110V before you go.
  5. astonbilla
    astonbilla
    Feb 19, 2002
    1,471
    +37
    Excellent
    Thanks guys!
