Transporting plasmas
Discussion in 'Plasma TVs Forum' started by sjallen, Oct 18, 2003.
  1. sjallen
    sjallen
    After extensive searching I've found a few threads with info on this but with no definitive answer to the following :
    Is it ok for me to transport around the 32PD3000 that I am soon going to be investing in?
    It would be upright in the back of my pug [306] estate next to my wheelchair with all sorts of pillows to the side and underneath it.
    Presumably they are built well enough to withstand the odd journey?
    By odd journey, I mean that it will be delivered to my home, then driven to Uni, then back and forth maybe twice, before coming to rest at home when I finish my degree in the summer.
    Thanks for any feedback.
    Steev
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    SHould be fine as long as you keep it upright. Try and tie it down with some soft fabric also.
    Neil.
  3. sjallen
    sjallen
    Cheers, that's what I wanted to hear.
    I've also just found C&M doing the Hitachi 32PD3000 for £250 less than JL - hoping for a price match :)
    If it breaks in my car can I steal your Panny, Neil? ;)
    Steev
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Steev manufacurers deler tend to use a flight case or special padded bag. Silly question how about using the box it came in???
  5. sjallen
    sjallen
    I plan to! When I finally get it. It will get added to the host of boxes I've collected over the years that get shoved into the garage and come out on special occassions :)
  6. adesonic
    adesonic
    Jan 28, 2003
    65
    Manchester
    I transported mine in this way (in its original pack) when I purchased it. I drove carefully, particularly ive bumpy bits and arrived home safe and sound with no damage to the plasma whatsoever.
