Transparent Dish- where from?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mhuk05, Mar 9, 2005.
  1. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Hello,
    does anyone know where I can buy an 85cm transparent dish?
    The best UK price I've seen is £70 + £12 p&p
  2. tim k
    tim k
    price sounds about right from what ive seen. there fairly pricey for what they are, try having a look on ebay's worldwide search, with the high currecy at the mo you might get it cheaper with p&p inc.
  3. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    You can buy Triax 88cm (not clear) on German Ebay in euros for less than we pay in ££.... Might go for regular dish and paint it red (to hide it on the brickwork).
  4. Pipsqueak
    Pipsqueak
    This is an old thread but has anyone found a good source under £70 for a 60cm one with LNB :confused:
  5. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    satellitesuperstore .com are the cheapest for transparent dishes (cheaper to get an lnb from fleabay).
    As they're still fairly visible, painting a normal metal dish the same colour as the background e.g. red oxide for abrick wall, green in the garden etc is another (cheaper) option and you'll get a stronger signal.
    Have a look on satellites co.uk for loads of good info & advice.
    HTH
