Yea - in a dark room it would probably be a bit more immersive, but other than that, you cant see it. It does work though as I specifically tilted the controller to watch it for a bit - but obviously cant play like that!
I am also a bit puzzled when people comment on the colour of the light bar. The one on the back of the controller.
Do we know how big it is in download size?
Sure does look crisp, and the audio from the DS4 is neat.
its optionalCan you turn it off or redirect it to main speakers?
I agree, I can't see the actual light, but can see the glow and the light bouncing off my fingers out of the corner of my eye and I think it's a good feature on the controller personally.For me, its the glow that adds to the ambience, you want to be looking forward at the TV, not looking at your controller to see the colour status, just like you don't want to be looking at the buttons you're pressing.
Yea it's off by default. You need to turn it on in Settings>General.Can you turn it off or redirect it to main speakers?
Is there a tutorial or manual for reference anywhere?
Zero explanation on weapon slots and what 'limiters' do. The devs sure were cryptic in their design!
Yea I've been using the terminals (as save points also) and read everything so far, and after an hour or so of play have two limiters, though I'm still unsure of what they do lol? :/Might be something on gamefaqs eventually.
Did you know that when you are at one of the terminals, you can press triangle on a weapon. This takes you to a screen with 3 tabs. The first is an overview of the power of the weapon. The second is a bio about who you obtained it from - and as you use the weapon more, more is unlocked about thst person. Gib ally the third tab tells you what that weapon does when combined with others. It's still pretty cryptic, but a bit of a help.
Pbb you're an absolute star.
