Transferring VHS tapes to DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by robarm, Jan 25, 2008.
  1. robarm
    robarm
    When I transfer old VHS stuff to DVD the results are OK but distinctly jaggy if you look carefully. I have just used bog standard Scart connectors - would higher quality ones make any discernable difference? I do have a Miglia TVMax which can digitise them straight to my Mac, but could I then make a DVD from the output?
  2. ramjet
    ramjet
    May 21, 2006
    3,761
    +622
    I doubt that you would improve the quality , but you could try making an mpeg on your pc or mac , and then use a suitable program to make a dvd from that mpeg
    but I dont think you can enhance the video unless you have extremely good programs , equipment and the time to do it
