transferring song from itunes to NW-HD3
Discussion in 'iPhone Forum' started by scratchyjase, Mar 28, 2005.
Tags:
  1. scratchyjase
    scratchyjase
    Mar 27, 2005
    603
    +9
    well ive finally gone for the plunge and ordered the Sony NW-HD3.
    The question i have got is that i have all my songs loaded up with itunes, can i transfer these to the nw-hd3 software or will i have to load them all up again?
  2. Akasan
    Akasan
    Mar 19, 2005
    68
    depends on the format...if they are mp3 or wma no...if they are aac u might have a problem
  3. scratchyjase
    scratchyjase
    Mar 27, 2005
    603
    +9
  4. drlau9
    drlau9
    Jul 22, 2004
    214
    Kettering, Northamptonshire
    +4
    Convert everything to Mp3,
    Click preference,on Itunes, then Importing, then Mp3 encoder.
    Goto your library, select all (ctrl + a), and convert all.
    or you can use a utility called riverpast Audio convertor.
    Dr.
