transferring saved programs to PC
Discussion in 'Satellite TV, Sky TV & FreeSat' started by RX Heaven, Jan 13, 2005.
  1. RX Heaven
    RX Heaven
    I want to know is it possible to transfer programs I've saved on the Sky+ to my PC for editing before burning to DVD ?
    What I want to achieve is to record MTV then pick and choose the vids I want to burn onto DVD for playing in my car
    Is this possible and if it is what do I need in the way of extra PCI cards , leads , and what editing software would be best ?
  2. Boy Lex
    Boy Lex
    Because the information Sky plus saves on the drive is simply the relevent multiplex stream (exactly what is sent to the dish), you cannot do anything other than play the media from the sky box and record it into your pc (as nice as it would be to be able to copy video files via ftp or something).
    So you need any PC video capture device and patience enough to copy stuff over in real time.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    All the data stored on the Sky+ HD is in encrypted format and has to be played back through the decoder. So the only way you can do what you want is to use a video/sound cable from the Sky+ box to a capture device on your PC.
  4. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    or record to DVD recorder (if u have one) then copy recorded dvd to computer and use TMPGNC DVD Author and edit the video and make a menu and then burn to DVD.
    thats what we do with recordings of Sky that we want to keep.
    jammy
