Transferring old tapes to DVD - Which hardware is best?
Discussion in 'Desktop & Laptop Computers Forum' started by newbiebie, Mar 31, 2005.
  1. newbiebie
    newbiebie
    Mar 17, 2005
    81
    London
    Hi all,
    I'd like to transfer my old VHS tapes to DVD as it seems VCRs are going the way of the dodo.. and I need the space it takes anyway for an AV amp now.
    Can anyone recommend a good video capture card that takes in S-Video and Stereo sound?
    I have seen ADS instant DVD 2.0 recommended by PC Mag but many users report the device becomes burning hot and freeze often. Is that true? Are there any good alternatives (good quality capture and stability) from Hauppauge or Avermedia? Or non PC solution from Keene or Lextropacks that would be recommended from experience?
    Thanks.
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,708
    J6 M5
    +215
  3. newbiebie
    newbiebie
    Mar 17, 2005
    81
    London
    Thanks.
    Will these external cards work for my old home-made video as well as to have 1 DVD copy of each of my old commercial VHS tapes?
  4. mhuk05
    mhuk05
    Jan 17, 2005
    2,708
    J6 M5
    +215
    You hook up your VHS player to the external box and connect the box to your PC (preferably a Pentium4 with a stack of RAM- I use a P4 2.8 and 2G RAM).
    The video itself should make no difference.
  5. newbiebie
    newbiebie
    Mar 17, 2005
    81
    London
    :confused: I have now found forums where it is discussed that the Canopus are MV protected although there is a jumper that disables it (!). Seems rather uncertain to me whether this will work or not. Could you be more specific with an external box model that is known to work?
