Transferring from Humax to PC
Discussion in 'Digital TV & Video Players & Recorders' started by Bulletguy, Feb 6, 2014.
Tags:
  1. Bulletguy
    Bulletguy
    Dec 24, 2009
    254
    +16
    I have a Humax Foxsat-HDR 320gb model and the drive is now virtually full with programmes i want to keep.
    Is it possible to transfer direct from the Humax PVR to one of the drives on my Dell PC?
    If so, what are the connections as unfortunately i don't have the manual for the Humax.
    Any help appreciated.
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,538
    Redditch
    +4,185
    Yes you can subject to your
    1 Your Humax and your PC both being connected to a home network
    2 You install the Custom Firmware add on
    Media & File Server Bundle for the Foxsat HDR - Release 4 - PART 5 | AVForums
    Replaying them once copied directly from your PC, without copying them back is a little more complicated.
    If you simply want to expand the storage, easiest way is to format a usb drive EXT3 (so it can cope with HD recordings greater than 4GB) to one of the 2 usb ports, once copied you can replay these from usb with the standard box with the standard software .
