Transferring files to Dell laptop
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by deocam, Feb 24, 2005.
  1. deocam
    deocam
    I have a Sony DCR-PC8E video camera and a Dell Latitude laptop C610.
    How do I connect the two?
    My options seem to be the USB port or a slot for removable cards (there are 2).
    What kit, leads, cards do I need and what software works first time, every time for a relative simpleton?
    All advice welcome.
    Adam
  2. thebrummy_one
    thebrummy_one
    Feb 9, 2004
    372
    East London
    +7
    Adam,
    before you incur the wrath of BJC :devil: This is becoming one of the most frequently asked questions on the forum to date. As such, we should put it on the frequently asked questions (FAQ) sticky at the top of this forum...
    Wait a minute, we have ;)
    Mark can say this so much better than me, but I'll have a go.
    You will need to get a firewire card for you lappy, a 4 pin to 4 pin firewire cable. If you are running XP, then you already have a good, basic editing program in Windows Movie Maker (MM) if you down load windows service pack 2 (SP2) then it gives extra functionality to MM. What would then intend to do with your newly created master piece?
    If you wanted to share it with your audience, then you might want to burn it to DVD. To do this you would want a DVD burner. (If you don't already have one) These normally come with a DVD burning program like Nero 6 (unless you get an OEM version) which, again depending on what version you get, gives varing results.
    Hope this answwers some of your questions. :lesson:
    Brum
  3. deocam
    deocam
    Thanks for the advice.
    The problem is that I don't have a firewire port on my laptop.
    I imagine that there is a slot in card of some sort that has a firewire connection? (I have similar cards that slot in to allow me to download files from compact flash and in days gone by I had an ethernet card)
    Am I still missing the obvious?
  4. deocam
    deocam
    Another note...
    Seems like I WAS missing the obvious. I have found a PCMCIA Expansion card online with 4x4 cable to boot! (I checked out the FAQs and this time it made sense) This should get me moving in the right direction.
    Thanks - A :clap:
  5. Brian110507
    Brian110507
    MOI ????
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,602
    Rainham Essex
    +2,543
    Et Moi! :D
    Mark.
  7. thebrummy_one
    thebrummy_one
    Feb 9, 2004
    372
    East London
    +7
    Bloody frogs!! :devil: ;) :D
