Transferring files - Basic question!
Discussion in 'PS Vita Forum' started by Forestred, Sep 1, 2005.
Tags:
  1. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    Guys,
    Again its another how does the most basic thing work question from me, I now have a PSP, 1Gb Sandisc card and a USB cable however my PC will not show me the card (which the PSP is happy with), is there some software that I need to use to transfer my apparently succesful video conversion?
    Please help
    FR
  2. SeedyR
    SeedyR
    Mar 26, 2005
    5,066
    +705
    Have you gone to the main menu (home) and selected usb connection?
  3. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    Um - yes! Well at least I have now.. I thought that Windows would recognise the PSP as a portable media device, I didn't realise that you had to effectively turn on the USB port on the PSP.
    Sorry
  4. SeedyR
    SeedyR
    Mar 26, 2005
    5,066
    +705
    No worries mate. You have to do it each time which is a bit annoying. As for video software, I use PSPvideo 9, to convert video files so they are able to be played on the psp, but no software is required to transfer the files.
  5. Bogside
    Bogside
    Sep 20, 2002
    3,028
    Stockport (ex Derry)
    +380
    If I was to get PSP video 9, how long on average would it take to rip a movie and then transfer it to the PSP. Are we talking hours or minutes?
  6. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,287
    +146
    It takes about about 2 mins to transfer a movie via drag and drop to the PSP. As for ripping movies it only takes about 5 mins with DVD Decrypter. Decoding it via PSP Video 9 takes about 15-20mins.
  7. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,454
    +6,231
    Have you got a supercomputer at home? Everyone else who uses PSPvideo 9 waits 1.5 - 2hr for it to encode a 2 hr film
  8. BuFF DaDDy
    BuFF DaDDy
    Jun 2, 2005
    3,287
    +146
    I have a high end PC yes, it all depends on how big the film is and what your system is like. Theres no hard or fast rule to how long it takes. It takes as long as it does.
    On average my films are anything from 20 - 2 hrs in terms of decoding.
  9. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,392
    Cornwall
    +93
    geez, i've got a 3.4ghz p4 1gb ram but my psp encoding takes slightly less than the playing time of the source material. are you encoding to avc or standard, and do you use cbr or vbr?
    mine is qscale 23, avc vbr.
  10. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,454
    +6,231
    figures...I've got a 2ghz PC with 512 ram
    that q scale stuff is nonsense
    I use AVC 160 kbps 64 kbps sound with 700% volume. 2 hour film = 180mb
    just put it on my PSP, looks supoib
  11. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    Does Windows recognise your PSP ok when you connect it via USB, XP goes nuts for me and often says it can't recognise the USB device - any suggestions?
  12. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,065
    Essex
    +74
    does anyone here no were i can download DVD Decrypter i have pspvideo 9 but i think i need DVD Decrypter
    any help would be much appreciated
    thank you
  13. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,392
    Cornwall
    +93
    dvd shrink does the job too. in fact imo it's better.
  14. jinky32
    jinky32
    Oct 17, 2004
    346
    +6
  15. luke_1983uk
    luke_1983uk
    Aug 26, 2005
    1,065
    Essex
    +74
    i have been looking forages and using google but thanks for finding it for me jinky32 that was a big, big help!
    thanks
  16. jinky32
    jinky32
    Oct 17, 2004
    346
    +6
    no worries :)
  17. soleus
    soleus
    Sep 16, 2003
    134
    Is it possible to transfer files through wifi from pc to psp :confused:
