Transfering Xbox game?????
Discussion in 'Xbox Forums' started by red2004devil, Jul 27, 2004.
  1. red2004devil
    red2004devil
    Jul 13, 2004
    217
    How to do transfer saved xbox games on 1 hard drive and put it on another xbox hard drive?????????????????
  2. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    use a flash ram memory card! (not just any, the ones made for the Xbox)
    Plug it in to a controller then transfer tha data. Some files are unmovable so u cant transfer those. Most games will work.
    The flash cards have their limits so if it fills up youl have to delete some files to fit other save data.
    Something else you could do, but im not sure if it would work is to conect 2 x boxes via an ethernet cable
    (Lan or RJ45cable) the kind you would use to conect your box to live.
  3. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    Do you mean the game save, or a full game that has been transferred to the Xbox HD?
    You can transfer game saves by using an aftermarket memory card (as above) which slots into the Xbox Controller. Using the "Memory" section from the Xbox Dashboard, you can copy/move saves from the HD to the memory card. Then just pop the card into the controller of the other Xbox - voila! ;)
    K.
  4. alastair
    alastair
    May 11, 2004
    53
    Northumberland/York
    I am doing GTA: Vice City and struggle and sometimes just want to cruise. I have a completed game for the PC version but is there anyway to dowload one from the net and burn it to CD or use my LAN from my PC to my Xbox?
    Alastair
  5. kelvin
    kelvin
    Apr 22, 2002
    1,598
    +45
    Check out www.xbox-saves.com :)
    A great utility (and resource), although you do need a mod-chip installed to take advantage of it...
    K.
  6. red2004devil
    red2004devil
    Jul 13, 2004
    217
    Its that my mate has downloaded the paris booster pack and long beach booster pack on project gotham racing 2 on to his hard drive each pack is 2996blocks, i was wondering if there was a way of putting it on to my xbox without downloading it again?????????
  7. Jason S
    Jason S
    only if you've got a modchip in each XBox
