M
mklar
I try to do the following:
(newbie)
Author a DVD using NeroDVDPlus, my LG 4081B and a DVD-RAM
Result: Burned DVD-RAM looking OK to me
I try to use this DVD-RAM on my Panasonic E50, but the E50 tells me: This disc is unformated
I tried to format the disc on the E50: Result: E50 can't format the disc.
I tried the option DVD-Video and DVD+VR, neither worked. According to the online-help there should also be an option DVD-VR, but it's not in my options-menu.
The DVD-RAM is labeled Maxell DVD-RAM *DATA*
Questions
Is there a guide anywhere (which I did not find till now)?
Will it work with a DVD-RAM for *video*?
Shall I use another software? Which one?
I found a lot of "Transferring from E50 to PC", but I want to do it the other way round. Thanks for your help!
Michael
(newbie)
Questions
Michael
