Transfering video to iphone 4S 6.1.2?
Discussion in 'iPhone Forum' started by cazshie, Mar 11, 2013.
Tags:
  1. cazshie
    cazshie
    Oct 17, 2008
    32
    On my old 3GS I had movies that I transfered from my PC to my phone, but when I sync my new 4S with itunes they dont transfer over?
    I can see them in "Films" in iTunes (and they are still on my old phone) but there doesn't seem to be a way to transfer them onto new phone through iTunes?
    The films I got via iTunes store have transfered over, but not the ones I had saved on my PC.
    Is there a procedure to transfer over?
  2. chukwe
    chukwe
    Aug 15, 2009
    5,136
    Welling, Kent
    +465
    You need to add the files\movies to iTunes library, then sync it with your iPhone
  3. cazshie
    cazshie
    Oct 17, 2008
    32
    I can see them in iTunes, but they just wont sync to phone.
    The film I downloaded from iTunes (Charlie Chaplin) will sync but the other 2 videos (mpegs) wont sync to the phone. When I try to play them in iTunes it says they can't be found, even though I can see them and they are on my old phone.
  4. chukwe
    chukwe
    Aug 15, 2009
    5,136
    Welling, Kent
    +465
    Try and covert those files to mp4 using handbrake and try again
