Transfering Sky+ Recordings to HDD
Discussion in 'Sky Digital TV Forum' started by Yanny, Oct 5, 2004.
  1. Yanny
    Yanny
    Is it possible to transfer what you have recorded on Sky+ to the HDD on a Panasonic DVD recorder (E85)? If not, how do I set up the DVD Recorder to record programmes on Sky without just pressing the direct TV record button.
    I have set up the AV2 input and output as per the DVD's manual but that is about as far as I understand :confused: !! AV1, AV2, RGB and all that stuff goes straight over my head so if you could keep it as simple as me I would much appreciate it!!
    Thank you very much. :smashin:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Not got round to getting a DVD/HD recorder yet so won't attempt to answer the questions, well I could but would probably get em wrong:)
    You'll find some threads on the E85 in the DVD recorder forum:)
