Transfering recorded items to pc?
Discussion in 'Blu-ray & DVD Players & Recorders' started by moid, Oct 18, 2005.
  1. moid
    moid
    May 9, 2003
    40
    Leeds - UK
    If I have a dvd recorder hooked up to Sky, record a program and then put it onto a DVD - can I then put the dvd into my PC and transfer the file to my pc to edit and store etc?
    I have heard rumours the dvd recorders protect the files so normal "dvd ripping" programs wont work to get the vobs from the DVD?
  2. illustrator
    illustrator
    See the frequently asked questions at the top of the forum, Rasczak guide to DVD-RAM (inc DVD-RW VR-Mode) To DVD-R should cover this one
  3. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Just rumours.
    For another guide, using different apps, see here...
  4. iantommo
    iantommo
    Jan 24, 2005
    27
    3
    +3
    Irip to my pc with TMPGenc and if just editing out adverts ect. just edit and author with TMPGenc
    Otherwise if I want frame accurate editing Iuse womble
    Hope this helps :thumbsup:
