  2. Notice: AVForums will be offline at 10pm for no longer than 30 minutes for scheduled maintenance. Apologies for any inconvenience this causes.
transfering analogue vid footage to ibook
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by junklunacy, Mar 1, 2003.
  1. junklunacy
    junklunacy
    I have a small dilema. I have got several hours of video footage taken on a Samsung analogue camcorder. Wotz the best way both expense and quality to get the footage transfered to an ibook running OS X for editing?
    Thanks in advance
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    AFAIK all modern MAC's (and i think this includes the ibook) have a built in DV port. So you can buy an analogue to DV converter for around £200 or go for something like the Dazzle USB analogue capture devices.
    If your Samsung camcorder is a Hi8 format then you could try to borrow a Sony Digital8 camcorder that will play back your tapes and allow you to capture via the DV port.
    There are several options and all should give final results that are close to the origional quality of the footage you have captured on your camcorder.
    Mark.
