transfer Wav files with sonicstage
Discussion in 'Headphones, Earphones & Portable Music' started by kravenz, Apr 12, 2005.
  1. kravenz
    kravenz
    How do you transfer WAV files to NW-HD3?
    I have used sonicstage 2.3 and 3.0; both same problem.When I tray to transfer wav files to sony device ( in standard mode), it automatically converts it to Atrac :confused: , if I adjust it not to convert, when I tray to transfer wav files, it says : not valid format :suicide: .
    Does any of you have had problems transfering WAV files?
    Best regards
    Kravenz
  2. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    That is because the HD3 does not playback wav files.
  3. kravenz
    kravenz
    No way to reproduce wav files??
    What about the product's official site specs
    Features ....
    SonicStage 2.3 software for easy music management and transfers
    Supports all popular digital audio compression formats: ATRAC / MP3 / WMA (non-encrypted) / WAV.
    Capable to store audio, visual and data files (Word, Powerpoint, ATRAC, Mp3, Jpeg, Mpeg, etc.)...
    Even my girlfreind's mp3 player (39€) does support wav :spam:
  4. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Yeh they are very clever with their wording.
    Supports
    It supports it, but it won't play it natively. When they say that they mean SS will convert all files that are not already atrac or mp3, to atrac. The only formats the HD3 will playback natively are Atrac3/Atrac3plus/MP3. I thought that it is compatible with WAV, because when you rip a Cd using SS, it allows you to rip it in WAV format. But it will convert it to Atrac if you try and transfer to the player.
  5. BUGANNA
    BUGANNA
    According to Sony
    the NW-HD1 did NOT play WAV or MP3 files
    and the HD3 DOES play them
    note: I had the HD1 before, and whilst it would NOT playback WAVs it WOULD transfer them, into Atrac+ etc
    So , clearly, the HD3 supports WAV playback, as why else, is WAV support mentioned ?
    ( the sonicstage software will always convert wav into atrac )
    What is meant by WAV support on HD3 ? and Not on HD1 ?
    clearly this means it will playback WAVs as if not, why has Sony specified wav for the HD3 and not for the HD1 ????
    I've spent 2 hours on the HD3 today, and STILL CANT SEE A way to transfer WAV files !!!!
    I tried doing it in file-manager, and transfered it as a normal wav file, but the sony doesnt recognise it, once u disconnect the pc link
    ANY HELP ANYONE ?
    :lease:
  6. BUGANNA
    BUGANNA
  7. BUGANNA
    BUGANNA
    Well, thats it, the HD3 does NOT play wav files
    which is actually the reason I bought it !!!
    I have no idea why Sony decided to state MP3 / WAV support on this player, when clearly it does not playback wavs
    SURE it will CONVERT wavs to atrac, but WE ALREADY knew that, as the SS software does that ANYWAY
    So, SONY have LIED and tricked people into thinking it plays WAV files
    My unit is going back for a REFUND TODAY
    20gb allows me about 12 CDs in wav format - good enoug for me, but the Sony doest allow it
    why ?
    whats the big deal Mr Sony ? are you trying to gain customers or not ?
    doesnt make any sense, SS is rubbish, and slows my powerfull pc right down, even the mouse movement is affected..........
    very poor................ :hiya:
