Transfer rate USB3 to internal HDD
Discussion in 'Microsoft Windows' started by A1944, May 10, 2016.
  1. A1944
    A1944
    Jun 16, 2010
    747
    46
    +107
    I have a Win 8.1 laptop. I also have a HDD in an external docking unit connected by USB3 and am trying to copy from it to the internal HDD on the laptop. The transfer speed is very variable and most of the time abysmal. For short bursts it whizzes along at 30-50 MB/s then drops for long periods to crawl along at around 100 kB/s or less. I am not doing anything else significant, so why the wide speed variations I wonder.
    Any ideas?
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,205
    Norfolk
    +2,339
    Are you transferring a wide range of file sizes? In particular lots of small files will slow down a transfer.
  3. A1944
    A1944
    Jun 16, 2010
    747
    46
    +107
    Yes, very different sizes. It seems that if I transfer in smaller chunks, the speed holds up better.
    I was trying to transfer about 150GB in one go, but with 10-20GB at a time it seems better, but is harder to keep track of.
    Still playing.
  4. A1944
    A1944
    Jun 16, 2010
    747
    46
    +107
    Well, I have managed to complete what I wanted to do.
    The trick was, as mentioned above, to do it in relatively small chunks. Even then, the speed was quite variable, but at least it stayed above about 2 MB/s most of the time and sometimes as high as 70 MB/s for short periods.
