Question Transfer movies from Sony HXD870 to Laptop?
Discussion in 'Blu-ray & DVD Players & Recorders' started by cvickery, Jul 14, 2015.
  1. cvickery
    cvickery
    Feb 11, 2008
    13
    Hello,
    I've read through quite a few posts on here and I'm expecting the answer to be no! I have a windows 7 laptop with HDMI. So is it possible to transfer the movies either real time or moving files using an HDMI lead or USB drive?
    I usually put the movies onto DVD's to watch in the motorhome when we are away. Just trying to make life easier/cheaper.
    Chris
  2. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,211
    +7,150
    I have to give you your expected answer unfortunately - No.
    The laptop HDMI is an output only, not an input... but there are many other reasons why it cannot be done.
  3. cvickery
    cvickery
    Feb 11, 2008
    13
    Hi Gavtech, Thanks for your reply. I'll get some more DVD's then.
    Thanks again.
    Chris
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,789
    Somewhere in South Yorkshire
    +6,399
    What you can do is (using a RW disc) make a DVD (using High Speed Copy) and then take the contents from that onto your Hard Drive (for which you will need, if it doesn't already have, a DVD drive and some extraction software on the laptop). In theory, if you use VR mode on your RW disc, you should I think be able to simply copy the movie and play it. In practice I have found that so doing often gives rise to some corruption and so I have tended to use Video mode which I have found more reliable. However to make a single movie from the contents/file structure of a video mode disc does require some software.
