Transfer ipod contents to pc
Discussion in 'Headphones, Earphones & Portable Music' started by quadman, Sep 19, 2007.
Tags:
  1. quadman
    quadman
    Feb 9, 2005
    78
    Help please, does anyone know of a good program that i can use to copy my ipod contents to my new pc? [it's 80gb video]
    Thanks in advance!
  2. Rattty
    Rattty
    Dec 30, 2006
    64
    +6
  3. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I use Yamipod :thumbsup:
  4. spl23
    spl23
    Jan 9, 2004
    2,672
    103
    +385
    There is a program called Music Rescue that will do this. I've yet to find anything free that does it, though.
    The alternative is to connect the iPod in drive mode, and drag the Music folder from it to your PC hard drive. You then need to reorganise the contents of that folder, so if you have a good MP3 management program, you get it to rename all the files and put them in an appropriate directory structure.
  5. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I told about Yamipod...:lesson:
  6. kevH
    kevH
    Oct 11, 2004
    833
    Live Leeds Work Chesterfield
    +37
    Ephpod is free too and has worked over an over for me !! :smashin:
  7. Poggy
    Poggy
    Nov 2, 2005
    187
    +3
    I have done this a couple of times manually - it can be done without software.
    Basically, copy the music files from the ipod to a temporary folders on your pc. I seem to remember that they are stored in folders on the ipod and you need to copy those foldersthem to the temp folder you have created.
    Then, open itunes and inturn, each of the the folders you have copied. (both windows need to be visible.
    Select all the files in the folder and drag them to itunes and itunes will sort them into the appropriate places.
    I'll have another look and see if i can make this clearer.
  8. fakker
    fakker
    May 2, 2006
    16
    3
    Use Winamp!
    it's free, and the plugin is now built into it... even works with the ipod touch.
    all you do is go to media playlist, select ipod... right click on the artists/albums and transfer to PC
    job done.
  9. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Does it work with Ipod Nano G3 or Classic too?:confused:
  10. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    It works with my iPOD Shuffle G1! :thumbsup:
  11. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    :confused::confused::confused:
  12. MarkusThatch
    MarkusThatch
    Dec 20, 2004
    9,989
    2
    +1,947
    i followed the apple guide to transferring my tunes (inc. 'purchased tracks') to a new mac and all went well apart from the purchased tunes - everything transferred to the mac ok but when i then try and update my nano it says 'not authorized to play them on this computer'. Is there a way around this?
  13. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Works on my brand new iPod Nano G3 8Gb! :thumbsup:
    I'm just now importing on my Win2000 based work PC that doesnt support the new 7.4 iTunes!:clap:
  14. Tomdale
    Tomdale
    Aug 7, 2005
    177
    Hello
    I just purchsed a 3rd Gen Nano.
    I downloaded the new version of itunes 2 days ago and I have lost all the CDs that I had in the library. I have tried to re-install using Winamp and from using the technique of reading from the hard drive but whilst the ipod is recognised on my PC the only contents it shows is the calendar and notes - no music files are showing on the PC.
    Can anyone help?
  15. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Never lost my Library in an iTunes update... not even the new one...:eek:
  16. Tomdale
    Tomdale
    Aug 7, 2005
    177
    OK - tried again to use the Ipod as a hard drive but it still does not come up with my songs.
    Any ideas at all??
