transfer from VHS
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by paulcollins14, Oct 11, 2003.
  1. paulcollins14
    paulcollins14
    Mar 18, 2003
    109
    16
    Hi Everyone,
    I am trying to capture footage from my VCR plugged into my pc via a Canapus ADVC-100 analogue to digital converter (scart to svideo/phono from VCR to converter and firewire from converter to pc). The audio and video captures but for some reason its in black & white. Whatever I do nothing seems to transfer the colour. Anyone have any ideas ?
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    You've probably got the dip switch set to wrong format, is this the first time you have used it ?
    The device is set to NTSC by default you need to change it to PAL. It's in the manual, if you can't find it I'll go into a little more detail.
    If it's not that are you trying to capture copy protected commercial VHS ?
  3. paulcollins14
    paulcollins14
    Mar 18, 2003
    109
    16
    I have the dip switch on the converter set to PAL, I know its working OK as I can capture from my analogue camcorder with perfect results.
    The VHS tape is a recording of a Central news program which I am trying to capture for work so it can be added to promotional DVD's.
    I tried tech support at Canapus, they said its probably caused by the cable runnimg from the VCR to the converter and if not that I need to send it back for a firmware upgrade. I don't understand, if it works fine from 8mm analogue tape why not from the VCR ?
  4. paulcollins14
    paulcollins14
    Mar 18, 2003
    109
    16
    Just thought of somthing else I could try, I have a Sony TRV33 which has svideo in. I will see if it will convert the signal.
  5. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Of course I was thinking when you said you were using an S-Video cable from the the VCR that it was a S-VHS player. Is that the case ?
    If it's a VHS player you will need to use composite out not S-Video cable.
  6. paulcollins14
    paulcollins14
    Mar 18, 2003
    109
    16
    No its a bog standard VHS. The cable I'm using is a QED scart at the vcr end and svideo with 2 phono cables at the other. Could it be that the cable which I spent £50 on just to try and sort this out is not RGB and therefore will not transfer the colour ? Or is that me being over simplistic ?
  7. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Standard VHS do not output S-Video (S-VHS do). I would imagine that is why you are not getting colour from your S-Video input lead to the ADVC-100.
    Try simple composite connections from VHS & see if that sorts it.
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    As vonhosen said, your VHS VCR will not output an S-Video signal. The only connection that will work is a standard composite. This can be output from the VCR via scart, but will connect to the converter as a single yellow phono plug (same as the red & white plugs for audio). No VCR's will output RGB either.
    So the £50 QED lead you have will never work with your VCR. As said above you need a scart to 3 phono plugs (Red & White for audio and Yellow for video). Also switchable as without the lead will only work in 1 direction as the scart plug uses different pins for input & output.
    Mark.
