DarkEntity said:Have you even attempted to search the Xbox forums or these?
i doubt it as if you had done so you would find that you CANNOT stream xvid etc through the 360.
The only way to stream any video media is with Windows MCE
elliothand said:I'm running 5.1 perfectly both in dvd and gaming playback. Got to use an optical connection to get 5.1 and make sure the settings have been changed in the system part of the xbox as well as the in game settings.
I think the creator mentionned something about looking at the possibilty to put 5.1 in the next release but I remember reading somewhere that I think it involves making the transcoder using a windows media encoder profile with 5.1 audio.tscotsman said:Anyone been able to stream divx/xvid and get 5.1 sound coming through their home cinema amp. Ive tried everything and cant get it
Jordans Norks said:The author of transcoder360 states on his website (a reply to the same question in a forum) that transcode can not stream 5.1 and converts down to PL - if you amp says otherwise it talking porkies![]()
I believe he stated that MS have messed around with something to make it difficult to do (stream 5.1 that is) but he'll have a crack when he's ironed out bugs in his product.
Great tool though!
