Trade my PS2 for your XBox
Discussion in 'Xbox Forums' started by Stevo99, Sep 29, 2004.
  1. Stevo99
    Stevo99
    Feb 13, 2002
    2,046
    +65
    Want to trade my PS2 for an XBox
    PS2, 1 pad, official memory card, slide card and discs to play backups and imports (therefore is unopened as slide card needs no modification)
    Looking to swap for raw Xbox, basically console and pad
    Any offer?
    I would consider selling too
  2. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    hia craig, got any pics of your ps2 showing the slide card?
    and could you just briefly explain what the crack is with it?
    can it play dvd-r,dvd-rw etc etc?
    what the age of it?
    which model is it?
    and a rough list of software youve got with it too? (i assume you have to have software to make the slide card work?)
    ill probably have a brand new sealed xbox with one pad,1 game - midtown madness.
    possibly a live headset too and a 2 month live trial code too.
    ill know for sure tommorrow mate, but if you can supply me the info above or have and questions of your own then fire away
    cheers
  3. Stevo99
    Stevo99
    Feb 13, 2002
    2,046
    +65
    H4r7y
    Basically the front piece comes off the drive for the slide card to work, it come with 2 boot discs. 1 for DVD and 1 for CD. Load the boot disc, when the prompt come on screen, put the card in, slide the tray open with it and slide closed again, press X and your disc will boot.
    Here
    This is the manual and contains pics, it looks more complicated than it is, its really easy
    Plays every type of disc
    It was purchased from play on 11/9/2003 so is just over a year old. Off the top of my head its version 7 or 8 i think but will check.
    I have Medal of Honour front line for it too. I have hardly used it.
    I'd be extremely interested in the trade if you can do it
  4. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    well if all goes well tommorrow then, i think were ready to rock, but obviously im not going to guarentee this yet. im waiting for a courier company to deliver the xbox to me, they said it should be thursday so once its here then ill give you a shout.
    have you had any problems with the laser or dvd drive?
    ps2's are a bit prone to going haywire once their past a year old expecially when using mods, slide cards etc.
  5. Marc
    Marc
    Jul 8, 2004
    11,720
    Titchfield
    +1,101
    just to reassure you, ive got the slide card thing he's talking about and the swap magic dvd works a treat on about 95% of backups, and should work on every pressed ps2 disc without a hitch. The only modification of the PS2 is that you have to unclip the front of the cd door, you don't void any warranties or risk damaging anything important.
  6. Stevo99
    Stevo99
    Feb 13, 2002
    2,046
    +65
    Fantastic, not had any probs with it, its not been used that much to be honest.
  7. Stevo99
    Stevo99
    Feb 13, 2002
    2,046
    +65
    Cheers for the review mate :smashin:
