Track order in MCE & WMP
Discussion in 'Microsoft Windows' started by MikeFish, Jun 24, 2005.
  1. MikeFish
    MikeFish
    Does anyone know why some of my albums play correctly (ie in track number order) when using MCE & WMP but some decide to play in alphabetical order of the artist?
    They are all numbered corrrectly and their filenames all start with the respective track number. If I look at my library in WMP the afffected albums appear in alphabetical order although no fields have been selected. If I click on track number it puts them into the correct order as expected. If I close it down and re-open it, it reverts back to listing them alphabetically.
    This only happens on a small number of albums.
    Any ideas?
  2. fathazza
    fathazza
    Oct 14, 2004
    589
    +34
    its because winamp loads up the albums in the order they are stored on your hard disk. I have the same problem with some of my albums and it is really quite annoying...
  3. MikeFish
    MikeFish
    Winamp? Does WMP use winamp?
    Is there anything I can do about it?
    I checked the folder the album is in and they are in the correct order there.
    You're right about it being annoying!
