Track ball pointers
Golliwogg
may i know anybody here has any experience using a track ball instead of a mouse? Is it better than a mouse?
EndlessWaves
Are you talking about the full sized ones or the integrated ones?
The full sized ones aren't bad, and some people prefer them to a mouse. They are far better than a trackpoint/trackpad.
cdldt
It depends on what you're looking for in a pointing device. A trackball only requires the space of the trackball itself, whereas a mouse requires space around it. If you're an AutoCAD user then you can pan indefinitely with a trackball, whereas with a mouse you run to the edge of the mouse mat and then have to lift it up and start over. Some people claim RSI is less with a trackball, but to be honest if you're overdoing things enough that a [good] mouse is causing you problems, a trackball won't help one bit.
There are a few annoyances though. Although modern trackballs are optical, you still have a moving ball, and I find that it gets gunked up with the same crud that gunked up traditional mice.
There are thumb operated and finger operated trackballs. I have a finger operated and there is a slight problem for using it with AutoCAD. Because you're using your finger to move the cursor, you cannot easily press the middle button (or scroll wheel) at the same time. I find that this slows me down considerably compared to a mouse. A thumb operated trackball is probably better for this.
phillyt
:thumbsup:
I use a Logitech trackball at work instead of a mouse. I got it to help me design in graphics programs being a graphic/web designer, and prefer it because the ball offers alot more sensitivity and control the pointer being in yoru complete fingertips rather than on a mouse where your wrist mopvement is not as controlled.
Trackballs also eliminate ALL problems with surfaces, skipping and jumping etc. Im so used to it now i got rid of my mouse all to0gether and dont think anything of it.
I also have no problem switching back to my mouse at home or on other PC's either.
Totally recommended!!
EndlessWaves
:thumbsup:
If your mouse is heavy enough that you need to use your wrist to do delicate work rather than your fingers I'm not surprised you find a trackball more accurate! :D
Gow87
i find a trackball not as sensitive as a decent mouse... A good mouse and mousemat(surface) seems to work best for me. gaming mice are fantastic due to the high DPI the sensors are high grade and i can move the mouse 1 pixel at a time quite easily
Perceval
Not sure if I agree with that. I use the large logitech cordless trackman optical and it is very sensitive even compared to the saitek 3200dpi gaming mouse I use. For work use I prefer the track ball.
If you use a laptop on the couch, bed etc, the trackball are a godsend, allowing you to give up on the rubbish trackpad and work/surf in a far more comfortable way.
Gow87
i use a cordless trackman myself? it might just be that it quickly builds up with gunk, i do all editing with a mouse and the trackballs been demoted to HTPC mouse... which i have to say is fantastic for that use!
triobot
trackballs are the bomb...
http://uk.kensington.com/html/7843.html
this is what i recco.... i've never had it but used it for gaming.... RPG, MMO, RTS, and a bit FPS oooh just remembered another one Black and White (wth genre?)
well it obviously depends what ur gonna do with it... it has a mussive scroll ring around the trackball...
its really pricey, but its worth it tbh. I would like to buy one tbh....
oooh i remember playing dungeon keeper for the first time with a track ball then i got totally hooked with them !!!
triobot
My experience of the mouse is v. good
heavy duty, big trackball, the scroll is nice...
thing is its been a while since i used it.... my cousin had it and prolly took it to HK with him.... gonna scavenge the UK house...
