The Grandfather
Hi, I have just bought a pair of a TP Link AV 600 power line adaptors. I have plugged them in and after they have synced I connected one to my Sky Router SR 102. The other end is connected to a Yamaha Musiccast WX-021 speaker. All I get is 'The sound of silence'.
Things tried:- Reset powerline adaptors, power Yamaha on and off, move powerline adaptors to computer room and plug into adjacent sockets.
I should add that they have always synced and display all three green lights. (Power, Powerline Sync and Ethernet). They give no indication of not working correctly but they are not passing traffic.
If I connect the Yamaha, by ethernet cable, directly to the SR 102 Router then all is fine.
I thought that these Powerline adaptors would be transparent to the ethernet signal. If I enter the Musiccast ip address 192.168.0.29 my PC (Mac) is unable to access the Yamaha speaker. Understandably!
Also the wi-fi provision on the Musiccast has been turned off as its signal in my wife's sewing room is not reliable and I wanted to force the speaker to only look for an input via its ethernet port.
Thank you in advance
Nick
Nick
