Monty Burns
Hey guys
I currently run two of these which are EXCELLENT in all but one area: the contrast ration is crap. Its really hard playing games that are based in the dark as you can't make out the scenery.
Anyway, I've decided to buy another touchscreen and move to a 3 screen setup so, can anyone recommend a different monitor please?
It needs to be:
edit:
I've found these two possible replacements -
Acer - low stand though so will not fit nicely with my "high rise" Iiyamas" but guess I could prop it up?
or
Dell - looks ugly (at least in pictures) and won't fit great, although better than the Acer!
I'm beginning to think the Iiyama is the only way to go as no other monitors will fit flush and will look horrible. Such a shame about that contrast ratio!!!
It needs to be:
- At least 1920*1080
- Ideally another "gloss" type screen
- dual input would be ideal, i.e. capacitive AND resistive ... but minimum is capacitive
- better than the crappy Iiyamas contrast!
- At least 22" (or bigger)
- no more than £250/300
- connect via HDMI or DVI (but I would assume this is a given)
edit:
or
