touchscreen jukebox...?
Discussion in 'Headphones, Earphones & Portable Music' started by strackal, Dec 12, 2004.
  1. strackal
    strackal
    Firstly apologies if im posting in the wrong section....?
    I need some help, and ideas if poss regarding setting up a touchscreen jukebox for the house.
    I want to have a small 7" or so touchsreen with some sort of jukebox software connected to allow to select tracks etc
    is it possible to connect a ipod to a touchscreen and connect up speakers?
    as i said, this is just an idea i have at the moment and dont know how feasible this is, if anybody has any thought/suggestions/guidance it would be MUCHO APPRECIATED!
    Regards
  2. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    You'd be better off using an HTPC rather than an iPOD, IMHO you could do a lot more with it, and it would be better quality, and storage would be much cheaper.
