Touch-screen screens visible in daylight?
Discussion in 'Home Cinema Control & Remote Controls' started by nathan_silly, Jun 6, 2003.
  1. nathan_silly
    nathan_silly
    My TC1000 is very hard to read in bright lit room (ok in darker room though)
    I do prefer touchscreen remotes, as I can add any button and move about, however I would like DVD navigation & select, volume hard buttons.
    And what screens are visible in bright rooms? I've seen the Lexicon remote and that's very bright (12V battery if I remember correctly)
  2. Jules
    Jules
    Oct 11, 2000
    5,091
    +767
    Marantz RC9200.
    Colour is quite visible in all but direct sunlight.
    15 hard buttons including DVD cursor, menu, enter, vol+/-, ch +/-, mute and 3 others.
    A fantastic remote if your good at programming it.
    I don't know how I ever managed without mine.
